Also, continuing on the exhaust...
If you go strictly by the numbers, the "ideal" exhaust layout for this motor and a 3500lb car is:
1x 2.5in-2.5out reactive muffler ~8-10" long (like a flowmaster or something)
1x side branch resonator, 2.5in diameter, you can play with the length depending on what drone (Hz) you need to cancel out, but between 28" and 40" is typically good enough. Locate it anywhere between the muffler and the 1st resonator (above) halfway is a good place.
I'll go in to side branch resonators later if there is any interest. If you want to see what a car with SBR's sounds like, look up "370z saclam" on google or youtube. SBRs are NOT "backpressure tubes"...there's no such thing.
If you really want to get technical with your car and go for that exotic car type sound, you can design a Herschel-Quincke tube set for your car (Ferrari's have this, so to NSX's, where it looks like a nest of interconnected exhaust pipes that loop back on each other) I might tackle this later.
If you split the exhaust like I will, cap it off with 2x absorptive mufflers (like a vibrant or a magnaflow)
-Zach'sV6
-Zach'sV6
