Motor Mounts? and an indoor AC drip.
FireSafetyGuy
Fort Worth TX
My neighbor mechanic has diagnosed a “shudder” I’m experiencing between gears when under a light load. When I turn the ponies loose I don’t feel that effect. He says it’s the motor mounts. Is this a known problem? Can anyone speak to it? My Gen 4 is 2018 at 120,000 miles.
ALSO! I seem to have an AC condensate leak into my front passenger floorboard. Can anyone advise the possible cause and remedy? Thanks!
Texas Marauder
Lone Star State
My guess is torque converter shudder. Has the transmission been serviced? Try a tube of shudder fix. If it works, much cheaper and easier than motor mounts.
Majestic
The leak is probably moonroof or cowl drain(s) blocked.
shootinirons
