How to tell?
Cnp22
Just a V6......
Cleburne tx.
Is there any way of telling if my pins have been welded In with out pulling it, (or going out and doing a huge launch and see if it explodes) the reason I ask is the guy I got it from didn't say nothing untill I asked him the he just said yea I did it when I did the clutch and motor he is a tranny guy tho, I'm really courios as to what's all done to this car I notice more stuff each day. I was under it today and noticed some brackets and little stuff painted red. If rode in two diffrent stock mtx shows before and this one is byfar faster than stock.
LOUDSHO92
Rancho Cucamonga, CA
Unless the owner told you I doubt it. It is relatively new. Most have a Quafie.
Cnp22
Just a V6......
Cleburne tx.
He said he rebulit the motor and tranny all I saw was a recipt from clutch... I mentiond the diff pins he kinda stumpled and said o yea I welded those also so I'm not sure if he lied or really did. I wish I knew who owend it befor him because I really want to know wants all done to it.. Also when I was under it today I noticed some new looking suspintion parts and some parts painted red.
HotRodKid
mmmmm ... turbo
Western NY
The only way to check is to pull the case apart, unless you decided to like bore a hole in the side of the case to peer inside, and thats not really the greatest of ideas.
Cnp22
Just a V6......
Cleburne tx.
Ok next ? I allso found that It doesn't have a timming belt cover top or bottom... How bad is it not running one?
LJRuddy
Pop lock n drop
Poaceae fields
Ran mine for ever without a cover due to it breaking into a gazillion pieces. Never had an issue.
gmail
Well-Known Member
sunbury pa
long as you keep it nice and clean under the hood and nothing close to the belt you will be fine...
as for the comment about doing burnouts till the diff explodes, if you were serious then your a idiot
hawkeye18
Sorta cares
Norfolk, VA
Ah, I never tire of seeing people use ****** grammar whilst insulting others' intelligence...
sperold
Last to Know
There are a lot of threads on this forum on welding the differential. Look them over and understand them, and then you can ask him what technique he used, or just ask him how many roll pins there are.... stuff like that.
If he is a tranny guy, there is a good chance he is not lying, because lets face it, he already made the sale, so there is no gain in exaggerating the facts now.
