what the ****?
Vnuk1
Mr. Mayhem
Have you looked at your wire harness going from your Distribution block on the firewall going to the battery and starter? They tend to break or corrode I have had a similar problem and that was the culprit, worth checking out IMHO...
RStalveyARFF
too many shos
Georgetown, MA
I don't really buy the no codes thing with it stalling. There should at least be a fuel pump secondary circuit failure code in there from the stalling...
xshoel93x
SHO driver
Massachusetts
yeah my stepdad checked that last night when it stalled on my mom twice. and he checked the codes again and still nothing. but im wondering if it would only throw a code when the problem happens and if everything is fine and dandy then it wouldnt throw a code? it hasnt acted up on him yet.
whereas the fuel pump was replaced 3-4 years ago by the previous owner just before we got it (she kept all her receipts and i have kept all mine and hers) were gonna go with CCRM and it will be here on monday. if this dont fix my problem im sure a cliff or a m16a2 would....
itwonder
VA
I would pressure test the cooling system to see if that new water pump is leaking on your CPS; especially if it's a rebuilt water pump. The next time she stops, be prepared with some gear so you can jump out and check the fuel pressure at the rail. Have a spare plug wire so you can pull one at the coil pack and substitute yours. Hold near ground while a helper cranks it over and see if you are getting any spark.
xshoel93x
SHO driver
Massachusetts
well, the water pump was replaced a year or 2 ago. the CCRM came in today, hopefully we put it in tonight and all goes well and i can goto work tomorrow for 6am without any problems
xshoel93x
SHO driver
Massachusetts
update: CCRM was the issue. cars all set. idler pullies and front brakes and exciter ring for abs this weekend.
thanks guys!
/thread
SHOspazz92
Banned
Triad Area, North Carolina.
It's called a back seat for you, my SHO doesn't have a back seat. It's built to haul a** faster than your SHO will ever see. And yes, this is probably why my cabin receives vapors.
Hey, I don't have a back seat and I have a FP door!
Weight012 1
My SHO is also built to haul ass and faster then both of yours. ;)
My fuel vapors are not caused from anything other then the car running so rich at all RPM's that it will choke you if your standing near after a few minutes at idle. w00t.
-Sam
Marccus
California
Nope. I've spent more hours working on SHO's than you ever will, so I know what I'm doing.
I'm with TYSHO on this one. I like lying on my back and reaching up with my hands. It gives me practice during ........
