DavesNOThereMAN
Does this tank have a siphon block in it? Can i just siphon all the old gas out?
you could just use the drain plug?
WTF are you smoking, and where can I get some?
x2 please
Just drill a hole and plug a bolt in there, and then you can call it a drain plug!
Im thinking since I want to change the fuel filter anyway, Release pressure at the fuelrail by doing the ol insert a tube and pin to catch some gas and then remove the fuel filter, put a gas container there and turn the fuel pump on.. The thing is what do I have to jump together to get the fuel pump to stay on? From What I remember its that extra little grey connecter next to the ODB-I test plug. But what am I supposed to connect that to?
I'm sure he was kidding. Don't drill a hole in your fuel tank.
The gray plug you're referring to is the SPOUT connector and has nothing to do with the fuel pump. The pump relay is in the CCRM, so you might be able to jump some wires there if you can figure out which ones. Why do you want to remove the gas anyway?
Is drilling a hole in the fuel cell really a good idea? Doesnt sound too bright to me.
Stuck brakes - Replace the parking brake cables and the flexible rubber lines in the rear. And check/**** the slider pins.
Oil pressure - Should be fine if there's no red oil light illuminating. Just check the dipstick to make sure the level is OK.
Misfire - First, check for codes. Then check the spark plug wells for oil. When the plug well seals fail, the wells can fill with oil and short out the plug wires causing a misfire. It's also a good idea to clean the MAF.
