Soft Button EATC to Round Button EATC
the4biddendonut
Hurry up meow.
Elk River MN
I'm sure we've all seen the old, ugly, broken button climate controls we've all come to call the soft button EATC. This How-To guide will show you how to modify your ugly soft button EATC into a nice looking Round button EATC.
First, you will need a soft button EATC from a 93 or newer. If you can't tell if yours is going to work or not, you can count the number of wires that are in the 2 ribbon cables that go from the main circuit board to the face. There should be 8 wires in each cable.
You will also need a round button EATC. They're commonly found in Continentals, Grand Marquis, Crown Victorias and other cars.
4482106070 fe4566c9a5
You'll also need the following tools:
-1/4" and 3/16" Socket
-T6 Torx
-Soldering Iron
-Desoldering Iron or Desoldering braid
-Solder
-Utility Knife
-Pick tool (not necessary, but comes in handy)
4482105906 4ee87309de
Soft button EATC
1) Start by removing the 4 screws on the back of the Soft button. Two 1/4" and two 3/16" screws.
4482106228 a1954cc1ab
2) Remove the cover.
4481457387 040306033f
3) Unclip the face. A pick tool comes in handy here.
4482106904 ed4f6fa648
4) Now the guts can all slide out the front.
4481458365 985bb61613
5) Unplug the Vacuum Solenoid connector from the circuit board. Set aside the Solenoids, they will be used later.
4481559863 658f145e04
6) Unplug the blower motor speed control dial from the circuit board (right). Cut or desolder where the illumination wires connect to the board (left), they will not be used later.
4481559769 12bb90ce01
7) Remove the illumination bulb holder and face. They should come off very easily.
4482108184 1a5e2ac7f8
8) Desolder the two ribbon cables from display circuit board, not at the main board. This will make it easier later, you will see why.
Hint: Find an electronic device that you don't want anymore and practice desoldering on it for practice.
4482108704 8567fcb909
9) This is what you will keep from the soft button EATC. The main board and the vacuum solenoid unit. The rest of my soft button unit ended up in garbage can.
4481459919 b13c106e8e
Round Button EATC
10) Now we'll work on the round button EATC. Start by removing the four screws on the back. Again, there are two 1/4" and two 3/16" screws.
4481460141 f56676e069
11) Remove the cover. Then, slide the guts out. Keep the plastic cover and case, they'll be used again.
4482109580 9a25fe019e
12) Unplug the vacuum solenoid unit from the main board and lift out. This unit will not be used, so mine went in the garbage.
4481460691 478866c51d
13) Unplug the blower motor speed control dial from the main board.
4481460921 44cfb6e906
14) Remove the five screws holding the display circuit board to the face with a T-6 Torx.
4481659209 3af73c9ed5
15) Remove the face and rubber button pad from the display circuit board, keep these.
Now would be a good time to clean the face of you round button EATC because you can pop the buttons out the front by pushing them from the back. You can also replace the bulbs with ease.
4481461445 d4f6ba2b8a
16) Desolder the two 8 wire ribbon cables from the display circuit board. Keep the display circuit board.
4481461597 6054ff37bc
Assembly
17) In this picture you can see why we removed the ribbon cables from the display circuit board. The ribbon cable on the left is from the soft button and the wider one is from the round button. It will be easier to solder because connections on the display board are further apart.
4481462015 273ea2b924
18) To get the more narrow cable to fit into the round button display circuit board, slice in between the wires inside the ribbon cable with your utility knife. Then, spread the wires out a little bit.
4482111386 9b64af5c39 m 4481462413 9a6ec3250d m
19) Now the ribbon cable from the soft button and round button display circuit board are ready to be soldered together. Be conservative with your solder, it doesn't take much. These connections cannot touch, or it won't work properly.
4481462589 a08cac2df9
20) Finished soldering.
4481462805 ff3aeb7683
21) Replace rubber button pad onto the display circuit board and fasten board to the face with the five T-6 Torx screws.
4481463089 828d48ffd1
the4biddendonut
Hurry up meow.
Elk River MN
22) Plug blower motor speed dial into main circuit board.
4482112466 87cf1032bc
23) Slide the main circuit board into the round button EATC case.
4482112740 743f7f2af9
24) Plug the vacuum solenoid unit from the soft button into the main board and place the unit into place.
4481464033 833e507b3c
25) Replace the cover from round button unit. Reinstall the two 1/4" screws and two 3/16" screws.
4482113406 eb2b7eba1b
26) Test before installation. Make sure all your buttons work correctly and that the illumination works. If a button doesn't work, you'll have to go back and check your solder joints. It's no fun going back, so do it right the first time.
Great success! It works like it should.
4481464493 32b00c2ba7
hawkeye18
Sorta cares
Norfolk, VA
This makes me very happy, and very sad.
Very happy because this is an EXCELLENT write-up, and is very well written.
Very sad because I remember when the last one of these was written! Not everything lives forever on the internet, it seems. I hope this one lasts longer.
the4biddendonut
Hurry up meow.
Elk River MN
I haven't had time to put it all back together. I'll get a picture when I get it installed into the dash of my 91 tomorrow morning.
In the mean time, here's a picture from my 93.
2677659599 20039cec0a
biker889
Quakertown PA
Was that in the car when you got it? did you buy that car locally?
moobypets
mooby
quebec
ok my question his my car is a 90
witch year range eatc will fit this 90 93 95 ??
im confused and im sure i could find a eatc for cheap but i just need to knwo wich year will fit or replace mine
green95
green95
Sebring, Florida
Was there a certain year for this style? The reason I ask is that your Round Button EATC has: MAX A/C, VENT, and the other buttons. The Round Button EATC that I'm looking at has: MAX A/C, NORM A/C, VENT, and the other buttons. It looks like the PANEL/FLOOR button is not on this EATC. I'm guessing it won't work, so what year did yours come from. The one I found is from an 2005 Grand Marquis.
