K-Dawg
DIS ground!
I triple checked the plug wires before i reinstalled the intake. It will idle until it starts warming up, but not steady. the RPMs vary between about 750 and 1500 while it's cold.
The rear intake support on the passenger side needs to be there it it a ground path and that is where a ground wire should have been connected.
K-dawg, the dis pack is damaged on the firewall side as in the connector is broken on the pack but the pins look good. I will take it off and clean it tho. does it need thermal compound? I can use arctic silver if i have too.
i have the ground strap solidly connected without the support. you can connect the ground strap to any point on the engine that has a good contact to metal, not just that one point.
It should be grounded to the intake manifold, so that the DIS has a solid ground
