supports between intake and head(wont idle now)
twitchblade
KC MO
I was wondering how crucial the supports were.
I'm replace the valve cover gasket on my daughter's '92 and was wondering if those could be left off as the ones between the engine and firewall were a pain to get off and I was thinking of leaving them off to avoid a major headache.
AREA 91
PA SHO SHOP
Area 91
They are not needed. The important part is to have a good ground path on the rear passenger side. This is where the ground strap attaches from the engine to the body.
P.S. I don't run them either. They get in the way of my sanity.
twitchblade
KC MO
cool, i didn't think they were and I'll tighten up the right hand bolt.
I just bought this for her and the valve covers were one of the known issues that had to be addressed for it to be dependable for her. going to replace the plugs and wires while the intake is off as it's easier to get to them.
AREA 91
PA SHO SHOP
Area 91
Good deal. Remember that if you are using a Chilton's manual, the firing order is wrong!!!
This is correct:
-----Firewall-----
5 1
6 2
4 3
---radiator-----
presidentpoo
Texas
the diagram is not turned correctly if the firewall and radiator are in those spots. the engine is transversely mounted so would 456 be facing the radiator?
hawkeye18
Sorta cares
Norfolk, VA
I know, I'm late, but I'm with all the others, ditch those stupid support things.
Actually, I left the front ones on in my wife's car because they're powdercoated and it seemed a shame not to have them on, but yeah, they're dumb.
And also, yes, the actual engine goes
1 2 3
6 5 4
but the coil pack goes
5 1
6 2
4 3.
The Chilton's, FWIW, also tells you to replace your supercharger oil every, what, 30,000 miles? Yeah, whatever.
Joe_SHO
ND
I ran my wires as shown in Chilton's? No problems.
SHOmethewayhome
BAD ROLE MODEL
Saint Paul, Minnesota
1 2 3
6 5 4
5 1
6 2
4 3.
your SHO didn't come with a supercharger? i change the oil in mine every 30,000 miles.:nut:
twitchblade
KC MO
I have a haynes manual, but info on the SHO is sketchy at best, so I'm doing like I usually do, I'm winging it.
:laugh_ti::rofl::nut:
i did find this pdf online and it had the correct firing order.
twitchblade
KC MO
well i got the gaskets replaced and now it wont idle.
any suggestions?
haven't pulled any codes except the 114 and I need to do the test with the engine running.
SuperHO
Mental Patient
St. Joe, MI
stupid question, but is everything that you unplugged plugged back in? also...did you put the throttle body gasket on the correct way? will it stay running with application of the throttle?
twitchblade
KC MO
I checked and double checked the connections, the gasket for the throttle body was damaged and currently has silicone sealing it, and will get replaced tomorrow on my day off, and it will run the the application of throttle.
hawkeye18
Sorta cares
Norfolk, VA
You did remember the big vacuum hose on the back of the intake AND the big grounding strap that goes to the bolt next to it, right?
Did you reconnect the IAC? The MAF?
