Eric VerValin
PiMPSKiLLET
Why would a car run up to 3000 RPM, then stall out.... and when unplugging the IAC... the car idles rough, but stays running...... I found that second part odd. Maybe because the car is still in "open loop" mode?
Not my car, just trying to help diagnose an issue.... I was thinking vac leak, or the IAC crapped... but I don't know...
Oh yea, no codes... well... once instance of a 542, but I'm assuming thats from when the car dies...
. Which all these shenaigans came after fixing a lower heater core hose coming off the coolant distrubtion block on the end of the rear head. Luckily Eric had one of these housings. Thanks, Eric
