How to turn off DRL (Daytime running lights)
firebat45
Edmonton
I'll swap my DRL module for the shunt/plug/thing if anyone actually wants to add DRL to their car...
I always thought they were stupid, myself. But to each their own.
fast Ed
Ford lover
Caledon, Ontario, CANADA!
Can a non-Canadian Gen 1 add in DRL then? It's one feature that my Impala has that I've really wanted on my SHO. I like to never have to touch the light switch.
DRL is not the same as auto-lamps. The DRL illuminates the front lamps (high beam filament on low voltage) only ... the taillamps do not get turned on.
F43Z 15A272 A is the number for a module for those who might wish to add it to a U.S. vehicle.
cheers
Ed N.
Guido0136
Mississauga, Ontario
No, the stock bulb (in a Gen2) is a 9007 which has high beams and low beams in one unit, so no luck there. As a side note, Gen1's use 9004 bulbs, same shape connector, different bulb pinout & filament orientation.
However, if you really want to totally remove your high beams, you can cut/remove the wire that feeds current to the high beam filament in the bulb. Here's the pinout so you know which wire:
9004vs9007
Obviously, you'll want to refer to the bulb on the right (the 9007), and ignore the bulb on the left (the 9004).
Good luck.
Regards,
Jon Heese
This turned out to be the quickest and most effective solution. All works great. no more DRL!
Thanks,
:thankyou:
shooff1994atx
On my 4th SHO
Goldsboro, NC
I used to have a 94 ATX..bought it when I lived in AZ, Then I moved to the Very North East you can get in Ohio and the weirdest thing..I suddenly had DRL..never got an explanation from anyone about that..
Guido0136
The jumper plug is cheap to buy from Ford, $9.59 is the Canadian retail price. P.N. is FOFZ 14489 A.
cheers
Ed N.
I know this is, like, ten years later, but I have a new 95 and went back to this post. I was able to buy the jumper part, new, and after an hour of searching, found the DRL module under the splash guard in the driver side front wheel well. Pop the wire harness out of the module and plug in the jumper plug and, bam, no more DRL.
Thanks ALL!
crystizel
