i figure the stock turbos will be good to the 11's, thats why i was kinda curious if anyone knows what kind of rating they have
hopefully i'll get all the exiting stuff done in the next week or 2, then we just have to work on the intake system
curious if the stock wastegates will be adequate too???
Terry, have you givin any thought to an e85 tune? im pretty sure the eccosho is e85 friendly and thats where id go next.
e85 oct rating is +100 i believe. however it will take "more" fuel to produce the same power.
i would say install a NESHO exhaust and spend a day on a dayno, with some e85 and just bump the boost a little each pull and go till your a/f's get iffy or you quit making power.. if your pushing 30 lbs at the manifold each turbo should be only running at 15 lbs. thats not a lot for that size of turbo. **** those old IHI's on the probe gt's are about that same size and 15 lbs on those was commonplace.
good luck
