Fort Wayne Tech Meet 10-17, Saturday
boat
Likes blue ones
Tallahassee, FL
Rod Bearings and Clutch?
Just wanted to give an update.
In the last week or 2 I have been noticing a strange feeling the clutch pedal. I pm'd sdpatt about, and his description was:
Originally Posted by sdpatt
I am sorry to inform you that the throwout bearing has worn the tips of the pressure plate spring fingers. If the clutch cable tension is not periodically adjusted to keep the TOB firmly against the springs, there will be sliding friction between the two parts that erodes the tips of the springs and results in the sensation you described.
I saw the results of this condition when I repalced my last clutch. With the TOB installed correctly and the cable tensioned regularly (whenever you think of lifting the clutch pedal with your foot), even the standard TOB can last 150,000 or more miles (and counting).
Sorry,
Scott
So in light of this, I am wondering the possiblity of NOT doing the front 60k w/rod bearings, but to do the rod bearings and replacing the clutch, TOB, and flywheel. Give me some feed back... and we can go from there. Like tools and equipment needed.
I am really GREEN, a NOOB and have never ever replaced a clutch in anything. I really need some guidance and help in getting this accomplished. I know that Eric V wants to get his MTX trans swapped, so maybe we can do both with the right equipment, and space permitting.
I am placing an order for a clutch and flywheel today, in an attempt to have it before next Saturday's meet on the 17th.
SHOracer14
Me-0 Diffs-6
Toledo, OH
I've done a **** of alot more trans swaps/ clutch jobs than 60k's. Lord knows I completely cleared NW Ohio of all available MTX's for a little while there. Nitrous and open diffs don't mix.
Boat... what type of subframe bushings do you have? Now would be the time for an upgrade with the subframe out. Other than an engine holder there are no specialized tools you should need... thank god that suspension was all recently apart so it should come apart pretty easily. Of course if you wanted to upgrade motor mounts and the trans mount now would also be the time.
boat
Likes blue ones
Tallahassee, FL
The previous owner put in Gen 3 subframe bushings maybe, 15k miles ago.
I replaced the front motor mount not long after the suspension was done with a SHO Source re-enforced motor mount. I just picked up a SHO NUT rear motor mount, and I have a newer trans mount, not sure if it is better than what I have now. I also thought about replacing the front strut rod bushings and LCA's, all of which I already have.
boat
Likes blue ones
Tallahassee, FL
Part order update.
The clutch was ordered this morning around 10am and according to Rock Auto, I already have a tracking number from FedEx as of about 3pm this afternoon.
I also ordered the new shift shaft bushings from SHONUT along with a resurfaced flywheel this afternoon. Josh said I should have these parts by or before the 17th.
Anyone have an engine support brace? Or should we take out of the top, since we are replacing the rod bearings also?
SHOracer14
Me-0 Diffs-6
Toledo, OH
If you have a harbor frieght local they sell one that's not too bad and it's pretty cheap. It's always a nice tool to have around when you're a SHO owner.
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Well.. let me re-state.... I have my hoist... its just locked up in a garage where the owner is still carrying out his 45 day sentence for being a bad little boy. I'm not buying another one just for sport. Personally I can swap a trans with a pair of jacks and a set of stands if thats the way it's gotta be.
The point of my trans swap is the fact that I don't have to spend any money.. :)
I was wondering however if Harbor Freight has an engine support. I swear I seen one in there a few years back. Not certian tho.
boat
Likes blue ones
Tallahassee, FL
Head count as of right now, if you want to come and are not on the list, feel free to add yourself,
Me
Bubba
Eric
Storm-Chaser
Jayro
SHORacer14
Maybe's on
Aleffewmo
SHOBill
Calypso
kzooSHO
SuperHO
What we are replacing, what I have:
Rod Bearings, Oil Pan gasket,
oil pump pickup tube
Have it
Clutch, TOB, and Flywheel Waiting for it, but should be here this week, Have ceramic TOB
Driverside Axle Have it
Axle seals Storm is ordering
LCA's have them
Strut Rod Bushings have them
Exhaust Manifold studs to
ypipe w/ lock nuts
have studs, waiting for locknuts
Rear main have it
Rear motor mount have it
Trans mount, (if it needs it) have it
Can someone bring a butane torch to heat up the exhaust manifold studs for easier removal?
Depending on weather and how well we are doing with the work load by lunch/dinner time, most likely for convience and time, probably will get pizza and breadsticks for the eats.
boat
Likes blue ones
Tallahassee, FL
It is a 1 and half car garage, with a 2 car garage door. Might be tight in there.
It is at 2222 Webster St. Corner of Webster and Creighton. Does he have the engine support, that you put over the top of the engine, rather than the hoist?
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Nope, he bought a hoist just like mine after he f'ed up mine.. lol nice huh... that reminds me I need another screw for the bottom of mine. :)
How do you figure it's a 1 1/2 car garage if it's got a double door.. lol ? does it get narrower by the door? lol
Mygarage
P1000306
there's a pic of the garage on Eagle St... is it that size?
Wish I had a better pic, but that truck and the Malibu fit in there.. :)
boat
Likes blue ones
Tallahassee, FL
No, half of it is big enough to get a car in one side, while the other side is about half the size. From the front it is very misleading, but the back half of the left side of the garage, well, its not there. The left side is about big enough for the workbenches that are in there.
SHObill
'The Collector'
Rochester MI-48307Detroit
Mike, you will have to add me to the 'maybe' list. will be possibly doin a clutch on my 89 or finishing up Tom's 90 engine swap, or spending the day with Beth doin a couple trannys.
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
I tell ya what.... since this started as a few hour rod bearing job, then developed into all of this, I'll probally just do my shit before hand, because I don't see it all getting done like you think it will. And I can't fart around with mine any longer. I didn't realize you could only get 1 car in there....
boat
Likes blue ones
Tallahassee, FL
If I am out of line on the amount I want to accomplish, then we can scale it down. I am NOT interested in killing everyone and making it a stupid hard day. Sometimes I have lofty ideas and want to get a lot accomplished, but I also want to be realistic too.
So, maybe just the clutch, or maybe just the rod bearings and front 60k?
Discuss..............
Sorry Eric. I will call you later tonight.
boat
Likes blue ones
Tallahassee, FL
It was brought to my attention that I don't have a time listed here for when we are starting. The plan is to start at 9am. As mentioned above the garage is at 2222 Webster St., here in Fort Wayne, IN.
For those of you coming in the confirm list, I will PM you my phone number so if you needed to call you can.
313tiger
