How much boost (or cfm) can the v8 take stock?
1bad98SHO
Fayetteville, N.C.
the injector is an on off switch basically. Only thing i could see messing with the flow of fuel coming out of the injector would be a vacuum of some sorts. I dunno.
firebat45
Edmonton
The high flow kit has that. Turns the fuel system into a semi-returnless setup, which has it's pros and cons.
Pro is more flow and no need for charcoal canister since you don't have heated fuel being sent back to the fuel tank.
Cons is that now you have a higher chance of boiling the fuel in the rails, since the fuel doesn't flow through the rails anymore, it just flows in and sits there until used by the injectors.
Personally, I think that the rails should be kept as a return style. If they can't flow enough for high horsepower setups, then run a feed into each rail and an return off the end of each rail. You'll have the same flow capacity as SHONUT's setup, but without the fuel heating. In fact, it'll be heated even less than the stock setup, that way.
Here, I've made a horrible diagram to put my text into pictures. Top is stock/Josh's base FPR, middle is Josh's high flow FPR, and bottom is what I'm going with. I've drawn the feed and return directions on each setup.
Fuelsystem
Off Road SHO
Moderator
I use the system that Firebat described in his third ...ummm... diagram. I had it polished though.
Tom
Sho Amo
SmkTyresntDrugs
Olney, Md
the fpr is at the end of your setup tom?
im kinda surprised that doesnt cause problems since the regulator is after the rail?
Ict_Lx
Back in School!
Marietta, Ga
AFIK, no one has really pushed the V8 motor due to lack of a sufficient transmission to handle to power. With new ATX's being run that seem to handle additional power (Eric) and people running around with Kirks MTX conversions, I expect that to change in the next couple of years.
SHO U UP
SHO Guru
Virginia Beach, VA
I'm shooting for about 8#s on mine, give or take. And the fuel system will be assembled and modified so their will be no fuel starvation. And of course, like Paul said, it has to be tuned correctly. The modified tranny should do it just fine. Normally, anything over 10-12 pounds on a stock block, other than a GT500 that I know of, will quickly expose the piston from the outside and you will have one helluva quick oil change. And why isn't this thread on the V-8 discussion section anyways?? :rofl:
firebat45
Edmonton
You do realize that the FPR is always after the rail right?
The feed goes straight into the rail and the FPR is on the return line coming off the rail. The FPR just "holds back" the pressure and lets excess past.
Tom, glad to hear it works for you. I wasn't sure if anyone had done the fuel system like that, but it made the most sense to me.
HotRodKid
mmmmm ... turbo
Western NY
did you know that if you say gullible real slow it will sound like green frog?
hey that isnt true !!!!
.my first thought was "thats impossible because green frog has 2 r's in it" so dont go thinking i actually said it out loud, lol
jasenklems
ohio
I heard that a mazda 6speed will bolt to the 3.4l v8 dont know if it true or not but thought that might help you out
MerkXRTurbo
Vancouver, WA
From what I understand, the 3.4 V8 is designed off of the Duratec block, so if there is indeed a good Mazda tranny that bolts the the Duratec then it seems reasonable.
