really dim headlights
greengiant
Holden MA
my headlights frankly dont do anything, i can hardly see at night, the lenses are clear and arent clouded at all but they are kinda low but even if they are low theyre still dim. anybody have any ideas whats going on?
97SHOgt
Cincinnati, OH
I would test the alternator and the battery. That's what happend in my '97 when the alternator puked.
firebat45
Edmonton
Quite a common problem. It's called "owning a SHO".
Joking aside, how did this happen? Has it been like that since you bought the car, did it slowly come on, did it happen all of a sudden? If it's not the alt/battery I suppose it could be the bulbs themselves, but I'd lean more towards wiring issues.
the4biddendonut
Hurry up meow.
Elk River MN
I upgraded the wires to 2 awg on the 93 and it brightened my headlights a bit. It wasn't huge, but it was enough for me to be able to tell the difference.
Get a 100 watt relay harness for the lights. Won't work with DRLs if you have them.
edwerd
Brooklyn, NY
frosho
WOLFMAN
Tyngsboro, MA
Feel the headlight switch after the headlights have been on for a while. If it's hot, replace the switch.
That's the good thing about the relay system. It takes the load off the original wiring 100%.
13.6 is too low. Should be 14v at the headlight plug with the lights on engine runnimg at 1500 rpm.
13.6 is on the edge of failure at 1500 rpm and a full electrical load.
If they are *******' about the brightness of headlights at idle they don't have a clue.
13.6 is the bottom of the barrel for a working alternator. 14.4 is what is should read new. a loss of almost a volt is a sure sign of a bad set of brushes or weak regulator.
It is doomed I tell ya. You could wait until it reads 12V then start a thread about how the car won't start.
jmpSHO
Massachusetts
Even with a new alternator on my SHO I never got a reading of 14.4 volts. It was always between 13.4 or 5 to 14.
