brake pad time
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
I was thinking that too but didnt say anything... because aren't the calipers and brackets the same up until 2004ish? I figured the rotors were the same too... intresting...
Gen 3 SLOs use the same as the Gen II SHO, 10.9" IIRC. The Gen 3 SHO is 11.6".
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
My Gen 2 had 10.2's I thought... well... maybe that is just 92-93, since the knuckles are different in 94/95? I would have to check a reciept somewhere to know what I actually asked for back then... can't recall off hand..
I know the G3 SLOs are the same as the G2 SHO. Can't say as I know what they are excatly obviously......
venom
Rowboat Design
Toledo, OH
My car is a SHO, but it took the SLO pads????????
The SLO pads fit on a SHO just fine mechanically. But there is about 1/4" of the outer diameter of the rotor that the pads don't touch.
If you have a sizeable ring of rust ont he front rotors after a few weeks you are runnign the SLO pads. I beleive it was foudn that if you use some of the parts stores lookup tools and you give them 96 SHO as the Model they will give you the wrong size (601) pads Give them 97 or later and you will get the 598's which are the proper size for the better braking performance.
