no cruise
sho4life
midwest
i replaced the module under hood, both switches fuses good. what else could it be?
RonPorter
SHO Club of America
Lake Orion, MI
If it's an MTX with the old cruise setup, check the vacuum line that goes under the dash to the pedal switch (IIRC for the clutch but CRS strikes!). I've had two of those go out over the years.
Only other possibility is the clockspring. I also remember something about if the cruise & horn both don't work, it's the clockspring.
JRA2000TL
The Complainer
Daphne, AL
My 90 has a habit of popping off the throttle body. There's a black line that connects to it that can sometimes come off.
beaudeen
BEAUDEEN
Shannonville, Ontario
Same boat here...horn works..fuses good..cable is on throttle..the line is hooked up to the brake switch..any other things to look at..was working for 4 years till the other day it just quit..???
RonPorter
SHO Club of America
Lake Orion, MI
Check the vacuum line more closely. Both of mine had a crack right at the connector.
beaudeen
BEAUDEEN
Are you saying the line to the brake pedal...was just thinking that the clutch pedal could be contacting that line and over time wear...are we on the same page..???
RonPorter
SHO Club of America
Lake Orion, MI
Mine just aged, and developed a crack starting at the end where it fit on the ******.
RonPorter
SHO Club of America
Lake Orion, MI
Vacuum is a key component for that old cruise system used on the MTXs, unlike the electronic system used on the ATXs. All three of my older Gen 1 & 2 SHOs had cruise issues, with the '94 having a bad clockspring, found with the inop horn (which also kills power to the buttons). Never had one of the actual cruise units go bad.
sho4life
midwest
its a atx, 94, horn works, so check a switch by brake *** a hose by throttle body?
94carolinaSHO
US of A
for my 94 if you look at the connector that connects to the module from the top, the last two pins on the left are melted. Any way to fix that? i was thinking about getting a new connector from a j/k and change it out somehow. Mine is an atx but what is a SCDS? So to the orginal poster check your connector.
beaudeen
BEAUDEEN
Didn't mean to hi-jack this thread, but just thought i'd chime in as the cruise experts seem to be here..anyhoo...found my problem..all lines are good..no cracks..none disconnected..however..the vacuum canister that drives the cable to throttle is split in half..looks like there was a V clamp holding it together..3/4 of it rusted right off..anyone have one of those..??
sho4life
midwest
checked that plug under the master cylinder looks , fine no fluid on it... so theres a switch on the brake pedal? gotta be it!!
waldo
Oklahoma
Hi folks, dont mean to hi jack, but does any one have a pi of what goes here on the brake pedal? mine is a 93 atx and ther is "some thing missing", just have no clue what used to be there, thanks!
