SHO_DOODmorrris
Owner & Fanatic
cool ill be sure to further test them! j/k lol i dont want to rape my transmission to hard
I want to say that I'm using Fel Pro HG's....16 psi tested on my end.
But you know what I mean.Great job on the build!
But I do have somewhat of a personal question.... I remember when I was 17.... and I don't recall having the income to do all of the things your'e doing, let alone while still in school.... I mean, I can do it now...but then, no.
Don't really mean to pry into your business, it's just that if it were me, I'd be putting all of this useless spending to something that will pay off in the long run. Not that have a fast car doesn'tBut you know what I mean.
Mitch sells his body on the streets.
-Sam
Heads are on, turbo is rebuild, clutch on order (CM3) waiting on cam tools then i can do my lash and put the valve covers on. will be pulling my engine on tuesday to scavange some parts (water pump, ckps, intake, and a few other little things) then ill drop my engine and tranny in temporarily to weld up my up pipe and down pipe and when thats fitted pull it apart again and throw my new clutch in. now we play the waiting game again. i hate waiting for parts![]()
Since this is a boosted application AND the heads have been worked, shim the valves on the loose side of spec. The valves will seat further into the head when you "boost" for awhile and take up the slack.
ughh... well on thursday i put together my spare transmission (in way better shape then the one in my car) and i realised that im missing one of the return springs. there is the first one that is closer to the case and the there is a smaller one that goes on the other end of the shifter arm thing closest to the gearset. can i just try to use a random spring that i found in the shop? or should i wait till i pull my other tranny off and use the spring from that?
-M
You dont need that little spring. Some of the earlier MTX4's don't come with that little spring. You can use a "random" spring if you want. Just make sure it isn't too strong. If it was me, I wouldn't worry about it.
P.S. Make sure you use anerobic on the tranny case half's, and output shaft seals so everything is sealed tight.
