My Engine rebuild... NEW PICS PAGE 5
firebat45
Edmonton
If you take your light bar/grill/bumper cover/bumper off, you get much easier access to the engine for all the wiring hookup and stuff, since you don't need to lean over it all. Only takes 20 minutes or so to do, I think it's worth it.
SHO_DOODmorrris
Owner & Fanatic
Alberta
CM3 installed with tranny on the engine now. also got my first part of the up pipe welded.
engine is going in the car tomorrow.
-mitch
SHO_DOODmorrris
Owner & Fanatic
Alberta
you have no idea... well actually im sure you do :p yeah its been sitting with a fricking garbage bad on its head for like a month now waiting for some ******* parts to show up but im just sick of it now and im throwing it in and doing the lash with it in the car and waiting to install parts when its on the car. still have a handful of work ahead and schools out on friday of next week so im pretty much at the mercy of canada post now...
Mitch
SHO_DOODmorrris
Owner & Fanatic
Alberta
Engine is in. Continued Welding my up pipe and its about 75% done. im STILL waiting on the order i placed at RCM over a month ago now... as soon as that order gets here i can do my valve lash ( i need the tools) and close up the top end of the engine.
On another note, i hooked up my old clutch cable to the fork and holy shit is the CM3 ever stiff compared to my stock one lol. i like it though, i never did like the smooshy engagement of the stock clutch.
tomorrow i will finish up the up pipe hopefully and mount the turbo to the transmission and maybe start on the downpipe.
-Mitch
SHO_DOODmorrris
Owner & Fanatic
Alberta
Update...
Turbo is mounted and I also did the waste gate ****** today. Man i will tell you guys ima lucky man, i made the up pipe off the car with the engine on the stand without the intermediat shaft installed and it clears by like half an inch and where they merge clears by like half an inch as well, good thing my mounts are bolted now so it shouldent bump too much, i might grind some of the subframe just in case. heres some Pics!!!
Here my Up pipe, its not done and will look much nicer but it should flow nicely!
main.php
main.php
main.php
main.php
main.php
main.php
And yes that is an open dump wastegate :evilgrin:
Here is the turbo, im not done the mount but its in there. as far as i know noone has mounted a turbo this way and i think it will work quite well. i know ht eexhaust manifold coming off the turbo is angles wrong but im taking that off and making my own ****** with a 3" piece coming off.
main.php
main.php
main.php
main.php
Up pipe poking up
main.php
main.php
Thats all for now! tomorrow is go time for the rest of the up pipe and i may start that ****** for the downpipe. and you guessed it... still waiting for the tools from RCM.
-Mitch
1993MTXSHO
Its a Taurus...
Jersey
Holy big picture batman! If you made those pics a little smaller it would be a lot easier for us to see, but it looks good from what I can tell.:)
SHO_DOODmorrris
Owner & Fanatic
Alberta
i know i'm sorry i'm a handy, someone teach me how to resize those puppies and ill get it done
-M
yamahaSHO
E85 whore
Arkansas
Open with MS Paint
-> Click "Image"
-> Click "Stretch/Skew"
-> Type "50"
-> Press "Tab"
-> Type "50"
-> Click "OK"
Save and close.
1995SHO9
FLEES ARE COMIN
Carlisle PA
What do you think?
I THINK, that he is doing a ******* awesome job. Props to you Mitch Mitchal, I'll be watching this build and ansiously awaiting to see what kinda crazy numbers you bust out. Your turbo looks awesome :)
I wonder if you are going to run into tuning nightmares like I did?
nik97
Mile high
Lookin good man. May just be the pic but it looks like you may have to trim the tab off the front of the MTX for up pipe clearance. I'm sure you are running into all kinds of surprises tho :) That's what makes it fun. Can't wait to see it run.
