SHO_DOODmorrris
Owner & Fanatic
Pistons are here
droping them off at the machinist tommorow morning
droping them off at the machinist tommorow morning Disclaimer: Links on this page pointing to Amazon, eBay and other sites may include affiliate code. If you click them and make a purchase, we may earn a small commission.
droping them off at the machinist tommorow morning UPdate... Engine is going out for machining and i get my pistons tomorow night. Looked into rotating assembly balancing and its gonna be about 550... i have no more money to spend of things like this if i want this engine to be in my car any time soon lol. ground all my valves and found out one is slightly bent so i need to get one replacment. guides are all tight as heck and im doing my seats tomorow morning. all my springs are within factory spec. gasket kit should be in by the end of spring break and reassembly will begin shortly afterwards. thats all for now folks!
For one: $550 for balancing is WAY out of line.
jesus im all screwed up now...
Update, Dropping off rotating assembly and block to be balanced and the block to be decked at a local machinist, balancing is 348 decking is 145 and flywheel resurfacing is 65 so thats all gonna get done in the next week or so. tomorrow morning if the pilot arrives i will be grinding the seats in the heads and should be busy with some other misc stuff. ill post up some pics soon. im extreamly busy and i have to go to the hospital 3 times a day for IV therapy antibiotics so life is a bit chaotic right now. anyways will post up details later.
-Mitch
If all possible, don't have material taken off of the block nor heads (or at least a very minimum). A couple of thousandths is o.k. to make sure the mating service is smooth/level, but any more than that I wouldn’t recommend. It throws off the cam timing ... the more taken off, the worse.
also if you plan to boost it, dont let them touch the crank. the only time ive ever heard of a sho's crank breaking is because they knife edged it and lightened it. this is a no-no because it is surface hardened.
