drdave
Jaxon,
You are essentially correct, but I do change the whole front of the unit, not just the faceplate. I scoped out the button/display board of new units and discovered that they are exactly the same as the old. Since all eatc units, old and new, use the same housing, what really changed was the electronics. The faceplate is the same size, but it doesn't line up with the old buttons.
The original units used a two-board design. One for the buttons and display and one for the lights. The new units use a board that houses the buttons and lights. But this board is 100% compatible with our units.
So it's not a big mystery, old back end and completely new front end. It does require de-soldering 34 wires and re-soldering 16. All of these wires are part of two ribbon cables. The ribbon cables on the new unit are a bit larger so they have to be modified a little.
But the bottom line is that when you are finished, you can hand this unit to anybody and it would be impossible to tell that the unit has been modified. Looks and works exactly like stock.
I think that what we have all been searching for is a way to use any eatc that we want, and this is by far the easiest way. With the right equipment, you can do this mod in under an hour.
If anyone is still interested, I will gladly post a step-by-step description of how to upgrade your eatc.
DrDave
DrDave
