yellow headlights
shomanv6
7000RPM
baltimore,maryland
:oogle: how do you get your headlights more clear without buying new ones?I heard you can use meguires mag alumimum polish is this true,any comments would be great.
wuzzzer
MN Moderator
St Cloud, Minnesota
Depending on exactly how bad the lenses are, you could use some type of plastic polish. I bought some at Wal-Mart and it's made a huge difference on my 97, and I'm sure it would help any year SHO.
They will need to be repolished every few months, though. Otherwise they'll start to haze over.
TheKrazyRaven
4 8 15 16 23 42
Lawrence Massachusetts
i thought i read on here once about someone using bleech <-- NOT MY ADVICE, if you try this and make things worse dont blame me, i thought i head about that before though
MAD MIKE
SHO STRIPPED
Muskogee, OK
what i used was 800 grit, then 1500 grit sandpaper, then i used some turtle wax to finish it up. they look better than new
Silver95
Niagara Region,Canada
when you used the 800 and 1500grit sand paper, did you wet sand?
MAD MIKE
SHO STRIPPED
Muskogee, OK
turtle wax isnt the best thing.... but it worked! got rid of the scratches the sandpaper made
tims (toolman) dad told me to use finesse, but i couldnt find it
SHOrespect
Spokane, WA
mine are really yellow too and I want to get rid of the yellow haze, I think I will try the sand paper thing
Slo-Sho
It wasn't me!
Crossroads, CNY
You can get brand new Mercury Sable headlamps and use your existing fish tank. These are much cheaper than even the $100 quoted above. It would be foolish to pay those premium prices...but more power to ya.
Bill Strobel
theamcguy
Fayetteville NC USA
New headlights have a UV coating to reduce the yellowing effect. Over time the coating deteriorates and you have the yellow headlight look. They can be polished (good recommendations on previous posts, I would use the 800/1500 grit sandpaper then a good polish with some kind of light paint polish, then a plastic polish if you have a buffer use that with a foam pad after the sandpaper). Problem is the polishing is a temporary fix. Without the UV coating (now completely gone from the polishing) in a few weeks the headlights will look the same or worse. Then you have to do the work all over again. The only permanent fix is to replace the lights.
SHOrespect
Spokane, WA
After you polish the headlights and if I were to apply a clear gloss, would the gloss act as a UV coating to prevent the yellow from coming back?
SHO Continental
Moderator
Northridge, Cali
new headlights!!
