shomanv6
7000RPM
how do you get your headlights more clear without buying new ones?I heard you can use meguires mag alumimum polish is this true,any comments would be great.Disclaimer: Links on this page pointing to Amazon, eBay and other sites may include affiliate code. If you click them and make a purchase, we may earn a small commission.
how do you get your headlights more clear without buying new ones?I heard you can use meguires mag alumimum polish is this true,any comments would be great.MAD MIKE said:what i used was 800 grit, then 1500 grit sandpaper, then i used some turtle wax to finish it up. they look better than new
Silver95 said:when you used the 800 and 1500grit sand paper, did you wet sand?
Bill Strobel said:New headlights have a UV coating to reduce the yellowing effect. Over time the coating deteriorates and you have the yellow headlight look. They can be polished (good recommendations on previous posts, I would use the 800/1500 grit sandpaper then a good polish with some kind of light paint polish, then a plastic polish if you have a buffer use that with a foam pad after the sandpaper). Problem is the polishing is a temporary fix. Without the UV coating (now completely gone from the polishing) in a few weeks the headlights will look the same or worse. Then you have to do the work all over again. The only permanent fix is to replace the lights.
