So I'm trying to wrap my brain around what this product will accomplish...I know phenolic spacers, in general, typically claim:
90 degrees? Wow.... So lower coolant temp is the benefit we will likely see greatest with this?So far I’ve notice an offset of 90 degrees on avg from coolant temps while towing a 2k loaded trailer (Ford Flex) at 75 mph
So far I’m happy with the outcome.
I’ll get some logs soon when I’m not using the car like a truck.
Hmmm doesn't seem like that would help with power. Can you describe the testing process? Where did you read Temps from? Did you datalog?
1) Lower intake temp by interrupting metal to metal contact
2) increase plenum volume
But not sure how effective it would really be with either of these. Air is moving so fast through the IM, I'm curious how much "heatsoak" it gets from the metal contact. The heat generated by compression of the turbos is what has the most effect on IATs. Even at idle, I'm not sure it effects it enough.
And as far as volume is concerned, I dont have any data on this, but my common-sense-o-meter just says this is a non issue considering the thickness of the spacer not being enough to make a significant difference.
Oh man, this is a difficult one. Aluminum conducts heat VERY well. Think of heat as energy, it moves it better than all but one other natural metal. I know that soaking my intake manifold in ice before a pull at the drags results in lower temps. So I would imagine that goes both ways.
Increasing the plenum volume would increase lower end torque. But how much is the real question.
I feel like someone should take temp readings straight off the manifold for before and after. I also feel like the volume change might not be enough to see on a dyno, but someone should dyno a before and after.
Idk, I understand how conductive aluminum is in regards to heat, but the heat the IM is soaking isn't just directly from the metal block underneath. It's surrounded in hot engine bay radiant and convected heat that a phenolic spscer cannot isolate it from. Not to mention, the hot engine coolant passes right through it via the thermostat housing and underneath it in a metal tube (I've had that tube ceramic coated for this very reason) soaking up that heat.Oh man, this is a difficult one. Aluminum conducts heat VERY well. Think of heat as energy, it moves it better than all but one other natural metal. I know that soaking my intake manifold in ice before a pull at the drags results in lower temps. So I would imagine that goes both ways.
You guys that run SCT tuners like the IAT2 temp because you can't see CAC_T lol. Torrie (in about 3 words) explained the IAT2 was a calculated temp number with less accuracy than the CAC_T temp output. But I agree the IAT2 is directly on the manifold.
I've also done the ice water trick at the track, and unless I'm running literally the instant after I spray it on, it has no effect, the IATs just rises right back within a minute or so, so as I'm approaching the line, it's right back where it was. I just stopped doing that altogether at the track because of that.
Yeah, I was thinking about doing that as well. I've had mine sent off to Jet Hot to ceramic coat mine.The spacer is what I've been waiting on to complete my anti heat soak protocol for the intake manifold. Got on the list as soon as I saw this on FB! Been waiting months since I saw a cad drawing of it.
Some 1/2 wall heater/HVAC pipe insulation for 1" pipe, wrapped in foil tape.
This coolant outlet pipe sees highest coolant temperatures in our engine. Our aluminum intake manifold surrounds this pipe within an inch on all sides.
The manifold spacer should reduce heat transfer from the cylinder head. I can't wait to get out all of my tc's and temperature capture equipment to see what the difference is with both of these mods in place.
200°f+ temps radiating off this pipe directly on to our aluminum heatsink of a manifold. At idle, on a warm day, 170°f IAT2 temps aren't uncommon after idling for 5mins or so.
High IAT2 temps definitely effect off the line performance.
Between runs? Amateur... Shut the hood with it still on there. Wait **** giving away my secrets... LOLI put a bag of ice on top of my engine/manifold for about 10min between runs. lol
