WTH? This ever happened to anyone else?
Lupo
Huntington Beach, CA
You know the rubber stopper on top of the foot e-brake that cushions it against the stopping bracket (with the brake light switch) when you release the e-brake?
My rubber stopper "devolved" into some disgusting primordial black tar dripping goo.
It is the messiest crud ever, almost impossible to get off anything. It makes anything it touches dark black. It looks like concentrated evil!! :omg:
I checked my other SHO, and the stopper is fine. It pretty soft, but it's not running off like tar.
Has this happened to anyone else? How hard is it to remove the e-brake bracket? Looks like this rubber stopper is riveted onto the lever, so I'll have to grind it out, get one from the junk yard, and use a bolt and nut to attach it back on...
Jonny Cash
Good boy
Hollywood, FL
It has!! :laugh_ti:
i thought it was just someones band-aid for a loose cushion!! Crap got all over my mocha carpet..
Shoman594
Moderator
Lockport, IL
Yes, sadly had the same thing happen on a 100 degree day. It basically melted and then went on the carpet. Nothing would get it out so I had to carefully cut it out of the carpet. :(
SHObill
'The Collector'
Rochester MI-48307Detroit
Yes I have experienced the 'Oozing Black Goo Syndrome' ! It has dripped on the carpet & the mat & has got on my shoe! Laquer thinner was the product I used to clean it up & off. It worked well! 3 bolts & 2 cables to remove assy but the upper bolt can be a PIA! drop the fuse holder down & use a long extension. I swapped in an ATX 'E'brake assy as its what I had. I then hooked up a vacume line to it so now my 'E'brake releases as soon as I start the motor. Mostly convenient, a few times not.
ohioshodude
SHO'ld fogy
delaware, ohio
yep mine did this too.. ruined the new carpet i put in the mocha.. guess i'll have to go the same route as ryan and cut out the messed up part.
svtnos
yea No i have never had that happen before.. lol good wording though...
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
I had this happen to my daily driver '89 on the way back from the Indianapolis convention.
The damn e-brake light kept flickering as we are hauling tail down the interstate.... so Id pull the ebrake up with my foot a bit. Then it would flicker again..... so I kicked it a few more times.
Next thing I know I have this nasty mess not only on my shoe.... but my nice clean carpet. And the e-brake light wouldnt go out :hpoop:
Those shoes are long gone.... but the stain on my caret remains.:doh:
ultimatesho
Fort Bragg, NC
sadlly both my 92 and 95 have done this.........always thought it was somthing put there intentionally to absorb the impact tho......guess not...lol.......cant do no damage to the 92 as its black.......95's gray carpet tho has black streaks all over it tho.....
Racer X
SHO Pilot, Retired
Connecticut
Yeah, I've been noticing this in the Gen 1's and 2's... it seems that whatever rubber they used was improperly cured, and it devulcanizing. It's friggin disgusting.
1993MTXSHO
Its a Taurus...
Jersey
i failed inspection cuz i had no rubber boot :) you could take it off like my car, but then its not good if your foots wet or something in an emergency.
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
Yeah, not the boot.
We are talking about the rubber pad that cushions the e-brake pedal when it is released. It also depresses the switch that turns the e-brake light off.
Mrhappytuzi
Divorced from SHOs
Delafield, Wisconsin
Yeah i was wearing sandals one day and that stuff got all over my foot. it took me a long time to figure out where it came from,..
VADERSHO
C-DAWG
Tulsa,Oklahoma
I just went out and looked at mine and Its just starting to get gooey I got a lil back on my hand, Is there anyway to prolong this? Wrapping the stopper in black tape? some kind of hardner?
zak
east of Hartford
Anyone got a Ford part no. for this thing? After reading this thread I'd like to replace - John H.
