Wtf!?!
Sammy~D
Wrench Whore
Anoka, Minnesota
No one makes a oil pump for a 93 atx im getting so frusteraited if you can help me i would be greatful
CerberuS
300 HP N/A SHO
Granby, QC, Canada
no one = how many places you looked?
Oil pump dont break , so theres plenny out there. junkyards or here in the classifieds.
wood_e
The dude
Ames, IA
+1 for the rod bearings. FWIW my 95 had 147k on the original bearings and I had no pressure problems.
Sammy~D
Wrench Whore
Anoka, Minnesota
wow i just found out that the shos dont have oil pumps their acually ran off of just vaccume lines
Minnesho
i was wrong
MinneSHOta
your kidding right? i really hope you don't actually beleive that...
Sammy~D
Wrench Whore
Anoka, Minnesota
ive went to auto zone, pep boys, checkers, advansed , napa ,and o'reillys and they all say sorry i cant get one so i went to ford and they said it is ran of of vaccumme pressure
CerberuS
300 HP N/A SHO
Granby, QC, Canada
nope its powered by the crank. its bolted to the block down , behind timing belt (of the crank)
Its unreal who much ppl donno jack shit , and they work in places like these.
wood_e
The dude
Ames, IA
Ok, its your rod bearings so why are you looking for a pump? If you want a pump get a used one. They don't fail often in SHos
Sammy~D
Wrench Whore
Anoka, Minnesota
cool.......cause it turns the light on after the engine warms up and ran for a litle bit after that
CerberuS
300 HP N/A SHO
Granby, QC, Canada
Rod bearings , dont use the car too much , if you wait , its gonna take a new engine.
Minnesho
i was wrong
MinneSHOta
Yes sammy. you'll park your car right away when you look at the rod bearings in the block i'm giving you ...
Mrhappytuzi
Divorced from SHOs
Delafield, Wisconsin
Well.. thats about the craziest thing ive ever heard about sho's.
btw.. rod bearings only cost about 60 bucks at autozone...
Minnesho
i was wrong
MinneSHOta
and they're pretty easy to install. i could be convinced to help you for a case of beer :biggrin:
whiteman_01
Well-Known Member
Hastings, MN
You'd be much better off going to rcm for your rod bearings. The cost is 60, but you get all the gaskets and rtv as well.
This is copied from their site
59.99- 3.0L-3.2L Clevite rod bearing kit
STD, .25mm, .50mm, .75mm under
Includes:
Clevite rod bearing set
Front oil pan seal
Rear oil pan seal
RTV silicone sealant (for pan rails)
Oil pump pickup tube gasket
Plastiguage
Bearings- made in USA
Seals- made in Japan
Standard size bearings will be shipped unless you specify otherwise
and the link
http://home.earthlink.net/~rcm_automotive/id16.html
