Woohoo!!!!
SeanMc
NoMoSHO
Something I had been predicting happened tonight, and get this...IT THREW A CODE!!!! I had thought my fuel pump was going, and tonight it went. Threw a 543 - Fuel pump secondary circuit failure. I have a new 155lph pump on the way :).
SuperHO
Mental Patient
St. Joe, MI
:shrug: That's why I've somehow managed to go 3 years without replacing my timing belt cover after my wife ran it over. It's a lot easier to change a CKP without having to pull the lower pulley off... :biggrin:
SeanMc
NoMoSHO
LOL. My car will sometimes buck, feel like it'***** the rev limiter (until it gets into a lower RPM), die, won't start, start and run for a second, die. I had thought it was my fuel pump, others were saying CKP, but no code would show up. Finally, it gave me a code after it died. Now if I start it, it will start, but if I floor it, the car doesn't go anywhere, and proceeds to die. Yes, I've checked the filter, and it's pretty clean. I'm just upset that I'm out of a car for a few days :(. On the bright side, I have a new 155lph Walbro on the way :).
SuperHO
Mental Patient
St. Joe, MI
Have you considered a cam position sensor? Not to burst your bubble or anything, but if the fuel pump don't work, consider that as your next option.
SeanMc
NoMoSHO
The one on there is brand new from RCM. Same symptoms before and after. After the switch, the 214 code went away and has never returned.
*EDIT* There is an ugly whirr and grinding noise coming from it as well *EDIT*
PhysicsSHO
Austin, TX
Fuel pump secondary circuit failure is set anytime you stall out the engine, IIRC. It's a common and unimportant code for MTX drivers. Possibly it's significant in your (ATX) case.
-Alex
'95 MTX
SHO Continental
Moderator
Northridge, Cali
oh, no pump, sorry.. so it'll either be replaced, or you're getting a ride to my house next weekend.. too bad we don't live closer, it's fun changing fuel pumps ;)
SeanMc
NoMoSHO
Matt (shokid13) and I may be getting together and and swap it. SPMotorsports said it would be here by this weekend via UPS, but like all my experiences with UPS, it's not here yet.
crystizel
