wont start
Harith
YamahaSHO
Minnesota
I just got a 94 atx, and it is very hard to start it sometimes.. I have to crank it for a long time and sometimes it i get a loud sound like the gears are grinding from the engine.. Eventually it does start and the engine runs like new.. I've heard it could be the cam sensor but i really dont know.. help please..
The wierd part is sometimes, it starts just fine but i can feel like there is more and more bad starts than the goods..
93rev2sev
Hockeytown
Probably a cam sensor. You need to pull the codes. Sounds like you have a bad starter or a flatspot on the flywheel, also.
Kens1992mtxSHO
The Commonwealth
So many different possibilities. I would pull the codes. It will give you a better idea of where to start.
You can find the instructions Here
Harith
YamahaSHO
Minnesota
thanks
thanks a lot for feedback.. i will try to pull the codes and get back with the results
