Won't start, HELP!!
SHOtime93
Michigan
I HATE MY CAR! Over the last week and a half my starter has been going bad and it won't start unless I hit the solenoid with the back of a hammer. Now, I have made and appointment to get it fixed, and in order to get the car in, it involves starting the damn thing and it won't start. I bang on the solenoid while my friend trys to start it, and it doesn't work anymore. It just makes that famillar clicking noise then a little mechanincal whine. Sometimes these damn cars are more of a pain in the ass than fun. Is there any other technique I can use to get it goin? Thanks for the help, sorry I just had to vent.
1993 White SHO ATX
Stock under the hood so far...
K&N Air Filter
1/4 mile 15.5 @ 92.4 MPH
400watt PPI amp and a single Fosgate HX2 12"
Powered by YAMAHA
M
MeShoHorney
Guest
I was thinking the same thing Rob. Check the sig. it's an ATX..
If it is the starter just pick one up and install it yourself.
Or try AAA to get it towed.
HTH
Jay
SHOtime93
Michigan
I ended up with a tow truck...yea what's another 55 bucks toward the well-being of the SHO??
1993 White SHO ATX
K&N Air Filter
Powered by YAMAHA
J
Jay97SHO
Guest
Originally posted by Rob94:
Did you try to push start it?
You tryin to be a smartass? I was gonna say the same thing,AFTER I saw the atx
Jason
Rob94
Northbridge MA
Sorry...was half asleep when I replied to the post....didn't even look at the sig. And Jason....you are the only person I would honestly suggest push-starting a ATX to....
Rob
White 94MTX
K&N Filter otherwise stock
pjtoledo
'ol man in the SHO
toledo,ohio,usa
SHOtime93,,where in Michigan are you? There are a few guys around Detroit/suburbs. Also a couple in Monroe. I frequently travel the Detroit area.
Perry Toledo,Ohio
Duff
Box Elder, SD
My starter went out over the summer--it made an awful noise over at a friends house when I started it, next time I got nothing, headlights stayed bright. Having an MTX let me roll back and pop the clutch to get to the shop.
95 Silver Frost
MTX, 63K mi.
No mods--yet
SHOtime93
Michigan
pjtoledo- I live in Grand Rapids. I know, there are a lot of SHO people in/around Detroit. Grand Rapids has a good number, but not all of them are on the forum.
1993 White SHO ATX
K&N Air Filter
Powered by YAMAHA
If hitting the starter solenoid with a hammer makes your car start, maybe it's not the starter that is failing. It sounds more like your starter solenoid. Much less expensive and complicated to replace. Might want to check it out before replacing the starter.
Scott
1991, 252K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
Class II hitch, Silver award at the SHOklahoma Car Show
