Bruce M
SHOBAM
1993 3,2L ATX (p)
Won't idle after 60K service. Changed the following gaskets, valve, intake, TB, IAB, EGR.
Idled but ruff before all this had oil in plug ports, bad wires and plugs. Now She runs nice when you throttle it by hand, hold it at 800 or so very smooth. Tested for vacuum around all ports and hoses, useing carb cleaner, could see no draw or increase/decrease in idle. Blocked intake with clean rag and a rubber membrain, cranked over for a second watched the menbrain pull into the rags becuase of the intake vacuum, could hear very very slight hiss like a pin hole in a tire tube that after a good minute would release the menbrain. not a high volume leak. Traced to it to where EGR vacuum reg hose goes into intake. Cleaned and replaced, no moere leak at all. Still no idle, IAB measures 9.5 ohms, book says thats good. Checked wire to and from MAF, TBS, IAB, all ring out with meter.
Had TB screw turned in a bit for other tests but it is back to factory set point. would run nice with screw tuned in a bout two turns but that would cause other problmes
any sugestions, do I just replace the IAB?
any help welcome.
any help welcome.
