Wheres the tps located?everytime i search it comes up keywords too shor . Ill just replace it since it seems cheapsounds more likely to be a tps than a mafs to me.
Turn key. Nothing. It was bad starte . Replaced it and havent had problem since.when you say it does not crank what do you mean? You turn the key and nothing happens,or it turns over without firing up?
Yup that was pretty easy. Replaced the tps today. Still notice a dead spot but im sure cats are bad. Going str8 pipe after I start at the new job and get settled in (doing brakes too). Then crank and cam sensors, possibly rod bearings though im sure something else will break before then.Good stuff. Its always good to hear sho problems getting solved.
I feel you on the cats. i know mine are bad, just barely passed smog today with a full tune up by Pulling the spout. been thinking about straight pipe with the high flow catless ypipe. just have to fix a few other things before i throw money at that.Yup that was pretty easy. Replaced the tps today. Still notice a dead spot but im sure cats are bad. Going str8 pipe after I start at the new job and get settled in (doing brakes too). Then crank and cam sensors, possibly rod bearings though im sure something else will break before then.
