Wont crank
if you want to, you can put a multi meter on the tps and see how the resistance changes as you open the throttle, but for what it costs, I would just replace it.
cali+Mocasho+
89 white 3.2 145k
califorina
when you say it does not crank what do you mean? You turn the key and nothing happens,or it turns over without firing up?
dugjt88
Michigan
Good stuff. Its always good to hear sho problems getting solved.
Yup that was pretty easy. Replaced the tps today. Still notice a dead spot but im sure cats are bad. Going str8 pipe after I start at the new job and get settled in (doing brakes too). Then crank and cam sensors, possibly rod bearings though im sure something else will break before then.
cali+Mocasho+
89 white 3.2 145k
califorina
I feel you on the cats. i know mine are bad, just barely passed smog today with a full tune up by Pulling the spout. been thinking about straight pipe with the high flow catless ypipe. just have to fix a few other things before i throw money at that.
dugjt88
Michigan
Luckily no smog or equipment checks here in michigan. Its just a daily driver for me so getting all the maintenance done and it running 100 is my priority. Been working on custom door pods for the stereo and hopefully in a couple months if nothing breaks ill be grabbing a ** alt for it.
