Wiring Diagram?
LookAtThatSHO
Who's SHO Daddy
Rochester, NY
I have a Pioneer head unit, amp, and 2 subwoofers for the SHO and was wondering if anyone has the wiring diagram for the head unit setup? Thanks! :thumb:
christiansho
Oshawa - Ontario - Canada
what do u want to know??? it has factory amps usually located in the trunk! the bypass plus are usually to the left of the factory deck allowing you to just run direct to the speakers. let me know how you are going to hook it up? and if u want to know the colours?
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
Buy the wiring harness (10 bucks) from best buy, etc that will plug directly into the factory harnesses (power and the plug that goes directly to the speakers located to the left inside the dash) and then you match those wires to the wiring clip coming out the back of your headunit. Clip all together and put in dash. Turn key on/acc and use.
The blue wire coming out of the back of the HU (remote) can be used for your antennae and can be your remote for your amp.
