Windshield Washer is on strike,..sometimes
Whitefish
Lamoine, Maine
My 94 Mtx is only washing my windshield when it feels like it. Because it is intermittent ( and because a Ford dealer steam cleaned gas off my engine this fall) I believe it might be a connection issue. Where do I find the connections and the pump for that matter? Any other guesses? It works 20% of the time. Not a good thing this time of year in Maine. Would also like to thank Scott for his rattle assistance earlier. Any cheap and easy solution to those noisey rear shock mounts?
Thanks
projectSHO89
SHOless In St L
The connection is on the bottom of the washer tank inside the fenderwell. You have to remove the liner to get to it. There's a good chance that the problem is your MFS, though.
BTW, does it fail to work when it's freezing outside, then works when it warms up or is parked in a garage?........You know where that one is going.....
No, they will have to be replaced. Good time for springs and struts.
Steve
rangerj
Brunswick, Ohio
Whitefish,
I thought Lemoin was in Iowa, and Portland was in Oregon! I was in Portland, Main, this past July.
To add to what Steve provided above, consider the following;
If it is the washer pump motor that is working intermittently, it is most likely a connection problem. It could be a failing pump motor. The pump and motor are at the bottom of the washer fluid tank at the end of the connection (heh heh)described by Steve.
If the pump is "pumping" but the washer fluid is not getting to the windshield, you most likely have blocked spray tips (the plastic tips that the washer fluid sprays through at the end of the fluid hoses). Minerals from "hard" water build up in the spray tips and eventually block the little hole.
The blockage can be remover with air pressure blown in the reverse direction of the fluid flow. Remove the sprayer, carefully as it is plastic and will break easily, and apply compressed air.
Sometimes it takes a piece of fine wire, like a straight pin, to force the deposits loose. The tips can be replaced for about $3 each from Ford.
If the pump has failed, or the pump motor, which also get gunked up with mineral deposits, it will need to be replaced.
I think you will find that an "aftermarket" pump and motor is much less expensive than an OEM (Original Equipment Manufacturer, i.e. Ford Motorcraft) pump and motor. They should be available from NAPA, Auto Zone, etc.
Maybe you will get lucky and it will be just a poor connection. rangerj
