Window Tracks
Slo-Sho
It wasn't me!
Crossroads, CNY
I'm having problems w/ my fr. pass. side window rolling up. It seems to want to come out of the track on the B pillar side. Are the tracks adjustable? shrug
pjtoledo
'ol man in the SHO
toledo,ohio,usa
Not sure if they are adjustable,(should be) but they certainly are corrode-able. Is the trim around the track swollen? I had about 4 inches of window track completely gone from corrosion on the 92.
Perry
There is a tack weld that secures a bracket to the track. The bracket slips into a receiver on the door frame. The tack weld has probably broken due to corrosion and/or impacts from many door closings. You can remove the track and bracket and have them rewelded if this is the case.
Slo-Sho
It wasn't me!
Crossroads, CNY
Upon further visual inspection, there seems to be no corrosion anywhere along the track and it seems to be very sturdy. I lubed the entire power window mechanism w/white lithium grease to no avail. Is this something I'm going to have to live with or is there another way? frown
JEFF_24V
Brampton, Ont
My driver side front windows is doing that as well, very annoying, it's worse at higher speeds and not as bad with the sunroof open. It makes a loud thump sound if I lower it after it has gone off it's track. My trims are corroded, but mainly on the rear windows.
Jeff
shoson
Bridgewater, NJ
No type of lubricant will help, I agree it sounds like a tack weld is broken. I have had this happen to other cars pf mine. Local glass shop should be able to repair the window regulator weld for about $50. if you can't or don't want to remove it yourself to have it re-welded.
