Window problem
BodylessSHO
Melbourne, FL
So, my passenger side window is rolling up outside of the door.
IMG_0453
I took my door panel off today, I couldn't see anything particularly wrong. Has anyone had this problem before? I can push it in and roll it up correctly, but if I roll it down and back up it does it again.
Ian Macoomb
Ottawa, Ontario, Canada
Never had that problem on my SHO but it's a major pain in the butt in my two beaters (94 Geo Metro, 91 Pontiac Firefly). The solution to that is to replace the window regulator. It's probably a little bit bent.
avocadoman1
Channel Islands, CA
if you're inclined to do it yourself (which is quite feasible), i'd suggest visiting a local junk yard.
you should be able to get the used parts quite cheap.
