Window operation
SeanDSHO
So last week I did a quick road trip to FL to visit family. The following morning I go out to take my brother for a spin and we find that both front windows (and the sunroof) have fully opened during the night. Anyone have that happen before?
Ta2dResqr
Central Ohio
It is the global open feature. I'm guessing you triggered it with the remote in your pocket or set something on it. Press and hold unlock for 3 seconds or longer.
SHOrod
Torrie Tuned
Cedar Rapids, IA
Similarly, you can use the fob to roll the windows back up and close the sunroof if you press and hold the Lock button. It's been awhile since I used this feature, but I think you need to hold the button until the windows are opened/closed to your desired height. If you release the fob button, the windows and sunroof will stop in that position.
-Rod
larryo340
Long Island
You can also disable that in the menu setting on the cluster
Ta2dResqr
Central Ohio
-Rod
I believe that is a Lincoln feature. I have even tried to enable Global Close in ForScan with no luck.
Correct. It is only a Lincoln feature. The Taurus' doesn't have the pressure switches to detect an obstruction in the window frame while closing.
Ta2dResqr
Central Ohio
I have heard this multiple times as the reason. I am not sure that this is the actual reason. Bounce Back protection is noted in the manual. If you use the auto up feature from inside the car and put something in the way, when the window meets resistance, the window will stop and reverse some. If you do it with the moonroof, the glass stops. There has to be another sensor or something that we are missing.
SHOrod
Torrie Tuned
Cedar Rapids, IA
Interesting. I didn't realize that was Lincoln only. I would have sworn that my former 2011 SHO also would roll windows up from the fob. But that was a few years ago since I owned it.
-Rod
shootinirons
