Will Not Even Click On Attempted Startup
NEILL93SHO
Yuma Az
Everything was working fine, then i went to start it and nothing..lights come on as normal, fuel pump ok etc..just no life to the starter..I am not much good with electriclal, but i am good at following instructions..Could it be the starter itself? I looked at the wires and everything seems ok. I switched the battery with a buddy and still nothing..any idea?
xpnsiv93
Corrupt state, IL
If the lights came on, and then u went to start w/no clicking or lights goin dim, then ya it sounds as if your starter took a crap on yA!!!
djsSHO
Ford Nut
Buffalo, NY, USA
Try givin the starter a few taps with a hammer...not hard but just afew light raps. If it starts up your brushes are goin bad in the starter and it's time for a rebuild or a remanufactured one :thumb:
NEILL93SHO
Yuma Az
i will try the hammer thing...the car does start when i push it..and runs fine. nNope, the lights and everything else seems to work..thanks
NEILL93SHO
Yuma Az
giave it a few taps and she fired up...at least i know what it is ...thanks guys
Isaac Marquez
blacktaurus91
Waterford, CA
can it be the wires? The other day I turned my key, everything had power, but no clicks. Just repositioned the wires a bit, and voila. Well, it didn't start, but it was trying to :p So that did the trick
The female spade connector to the solenoid gets loose over time. You can crimp the connector small amount to get a better fit.
ribeye2065
