When should the fuel filter be replaced?
ACV1081
Member #187
IA US
When should the fuel filter be replaced, how hard of a job is it, & where & how much are they? Loaded sentence huh? I just want to get the SHO ready for winter & just did an oil change yesterday so figured I'd ask bout the fuel filter while I was ambitious. Any help is great. Thanks in advance.
1004303681370 NEW SHO PIC 102901
~Adam Varney~ mailto:[email protected][email protected]</A>
1993 RED ATX(3 replacements) W/shiftkit, 130,000 miles, 17" Konig Reigns, 245/45/17 Goodyear F1 Gs(Summer), 225/55/16 Blizzaks WS-15's on slicers for winter duty, 26mm ASB w/poly bushings, Tweaked stock airbox with K&N panel filter, D4U1 computer, blazertech fogs, & performance friction brake pads. GTECH time 0-60 in 7.02 1/4 15.58 @ 91.
Not yet installed: SHOSHOP Stut tower braces(front & rear), 24mm ASB(spring), all 60K service items, & rest of the poly bushings... Upcoming: Definitely saving for a y-pipe. GOING TO TEXAS Dec. 26 TO HAVE SDPATT DO 60K!
TwiceSHOwn
Atlanta, Ga
I always have heard 3 yrs 30,000 miles. Its easy to change its right in front of your passenger rear tire. They cost like 10 bucks and it takes like 10 minutes max to do.
94shoboy
south shore, mass, usa
i change mine once a year, usually when i detail it in the spring. make sure you get new plastic clips to go with the filter. the factory ones usually snap. make sure you pull the gas cap too, it releives pressure. a couple cups of gas will come out, thats normal. i would say just do it once a year, if you drive it a LOT, then every 6 months. its worth it for the 5 minutes(takes me about2-3 now to lie down, pop the two clips, pull it out and swap in the new one)its worth it just to make sure that its good and you won't have any probems with it.
RStalveyARFF
too many shos
Georgetown, MA
by the book, it is every 10k. Fred is correct.
Erik
15.466 @ 92.56 and 15.514 @ 91.91
White 91 Bought 5/12/01 131k
Mods:
Cold Air Induction, Clutch, PP, TOB, Pin just replaced, DIN sized switch panel (replaced cup/coin holder), Fog Light Mod w/ 100w driving lights, Lettering filled in: Black, LPM, Nokya 80/100w blue beam headlights(Thanks SHOTIME), Painted calipers: Red, Painted intake: White tanks/Black runners/Gold lettering, PermaCool dual 12" Electric Fans, Police Grille, Police Interceptor Emblem, Port Matched Intake, PRO-FLOW 77mm MAF, Resonator Removed(not by choice!), Removed Intake Horns, SHO-NUT Reinforced F & R Motor Mounts, Shortened Shifter, Superchips Module(thanks SHOTIME), Surge Tank Restriction Removed, Tint @ 35%
Newly Added: 2 EL8a Amplified Bazooka 8" Bass tubes (Thanks §weetheart :D)
Every Possible Option =)
Go Fast With Class
AIM:SkiSalomon & SHOmetheSpeed
Blast7
Rochester, NY
It is a very easy job. It is on the passenger's side right before the rear tire.
1991 Black MTX
K&N Filtercharger
PP Motor Mounts
Rod Shifter
Blazer Tech Fogs
Want to Buy:
~1st Gen Black rust free trunklid
~1st Gen Black rust free front door mouldings
