Ok the hissing noise is coming from the vacuum lines running into the shifter area. Actually the lines themselves aren't the problem it is the disc that rotates when the shifter is moved into gear. I played around with it quite a bit but to no avail other than removing the lines altogether. My question is what do the lines do & can I unhook them to aleviate this annoying hiss? Please look @ the pics & let me know what those lines do as soon as you can cause the console is torn apart
Thanks guys you are invaluable!
~Adam Varney~ mailto:[email protected][email protected]</A>
1993 RED ATX(3 replacements) W/shiftkit, 130,000 miles, 17" Konig Reigns, 245/45/17 Goodyear F1 Gs(Summer), 225/55/16 Blizzaks WS-15's on slicers for winter duty, 26mm ASB w/poly bushings, Tweaked stock airbox with K&N panel filter, D4U1 computer, blazertech fogs, & performance friction brake pads, SHOSHOP Stut tower braces(front & rear). GTECH time 0-60 in 7.02 1/4 15.58 @ 91.
Not yet installed: 24mm ASB(spring), all 60K service items, & rest of the poly bushings... Upcoming: Definitely saving for a y-pipe. GOING TO TEXAS Dec. 26 TO HAVE SDPATT DO 60K!
[This message has been edited by ACV1081 (edited 12-20-2001).]
