Many of you have seen the very custom SHOpala, and now you can own it!
I will not spend a lot of time typing about it, but instead let the mod list and pictures do the talking.
It is custom painted Graphite Pearl with full black leather interior. It has a N/A 3.2 V6 with lots of modifications. Custom front clip with Impala Headlights retrofitted with BMW E46 HID projectors.
***2005 Indianapolis SHO Convention Gold Award Gen 1 Modified, Voted Best Paint, and Tied for Popular vote BEST OF SHOW***
MODIFICATIONS
ENGINE & INTAKE/FUEL/EXHAUST
-3.2 engine swap from ATX SHO
-Port Matched Heads
-Midwest SHO Stainless Steel Catted Y-pipe
-Stainless Flex Pipe
-Borla Cat-Back Exhaust
-Kirk D���s Reinforced Motor Mounts & Transmission Mount
-Custom cold air box
SUSPENSION & BRAKES
-Eibach Springs
-ZERO mile, BRAND NEW Tokicos
-Full Body Sub Frame Connectors
-Rear Tubular GM Adjustable Control Arms
-H-Brace
-TCE Rear knuckle braces
-24mm Front & 26mm Rear Sway Bars
-TPR and Greasable Poly bushings
-Moog outer tie rods & greasable ball joints
-Aluminum Sub Frame Bushings
-Police Front & Rear Strut Mounts
-Windstar Front End links
-17" Forged Chrome Centerline RPMs
-Kumho MX High Performance Tires (235/45/WR17)
-12.5����� Modified Corvette PBR Dual Piston Brakes
-Vented Rear Discs with Bias Plugs
-Earls Stainless Steel Braided Brake Lines
-1" Aluminum CNC hubcentric wheel adapters/spacers... rear wheels sit perfect now just inside fender.
DRIVETRAIN
-Quaife Torque Biasing Differential w/ rebuilt Sho Shop Transmission
-New Oem Ford Clutch
-Sho Shop 17 lb. Flywheel
-Jose���s SHOshifter w/ braces and shifter boss upgrade
-GM Synchromesh MTX Fluid
INTERIOR & AUDIO
-Full Black Leather Seats w/ 93 black center console and steering wheel/airbag
-93 Black Rear Package tray w/3rd brake light delete.
-Schroth black 3 point harnesses w/inertia sensors (Means they���re street legal)
-CDE-9843 Alpine Head unit with MP3 & WMA capability
-Alpine Type R 6x9��s in rear deck
-JBL 6 ����� front door speakers
-Optima Red Top Battery
-White Faced "Reverse glow" Gauges
-AutoMeter Electrical Oil Pressure, Water Temp, & Volts Gauges
-3 Gauge Pod (A Pillar)
-Battery Relocated to trunk w/ Billet Aluminum tray
-Gentex Compass & Auto Dimming Mirror
- hard wired for radar detector to key on
-95 Hard Button Climate Control
-Remote Keyless (w/key FOB) entry from a 95 SHO
MISC. AND COSMETICS
-Custom front clip with CincySHO cowl hood integrated to police style grille
-2000 Chevy Impala headlamps retrofitted w/01��� BMW M3 projectors
-4300K Philips D2s bulbs w/ upgraded harness & relays
-Generation 3 Hella Ballasts
-Hood Strut Relocation kit
-Acura 3.2 Badge on Front Grille
-Fiero GT rear spoiler with shaved pedestals so it sits lower.
-Functional Side Scoop off an 80���s something Charger
-Rear quarter panels off a 95 SHO.
-All 4 doors are off a 95��� SHO with the color matched door handles.
-Custom LED brake lamp molded into trunk beneath spoiler
-Shaved Trunk
-Filled in Body Lines
-Filled in Taurus on side body cladding.
-Momo stainless racing pedals with a dead pedal added
-Powder coated Intake and Valve Covers
-Powder coated Sub frame
-2.5% tint on rear window
-5% tint on rear passenger doors & quarter glass
-35% tint on front doors
MAINTENANCE ITEMS
Engine and all parts mentioned during build have very low miles, under 10k.
-Rebuilt 3.2 V6 out of 93 ATX SHO
-3 Angle Valve job on Heads
-Polish Cam Journals
-Rod Bearings Replaced
-Main Bearings Replaced
-New Rings
-Polished Crank
-Honed Cylinders
-All New Valve Shims installed
-All new gaskets and seals
-New Motorcraft plugs and wires
-3.2 oil pump was utilized
-All new A/c: Compressor and lines, so fully retrofitted to R-134
-New O2 sensors
Car is not perfect, has some paint flaws and some underbody surface rust, but overall is very very clean. Many pictures to follow. I know the body mods are not for everyone, and to be honest, its radical look is part of the reason I am willing to part with her. I have found she looks a little to young for my tastes. But I will say, I have received more looks and compliments in the few months I have owned this car than in the other 14 years (and 15+ SHO's) of SHO ownership. A head turner for sure.
Asking $5000.
MODIFICATIONS
-Port Matched Heads
SUSPENSION & BRAKES
-Eibach Springs
-H-Brace
DRIVETRAIN
INTERIOR & AUDIO
MISC. AND COSMETICS
-Shaved Trunk
MAINTENANCE ITEMS
-New Rings
-Polished Crank
-Honed Cylinders
-New O2 sensors
Asking $5000.
