Crank Position Sensor. it uses an electromagentic pulse to detect where the crank is. its purpose is for timing.Derek:
What does CKP stand for and What is its purpose??? shrug
CPS = Cam Position Sensor.JoeHoe_SHO:
I thought CPS was crank position sensor![]()
The CMP sensor was also once refered to as the CPS. Actually Ford used to use CPS for both the CMP and CKP sensors. New and updated terminology (as previously posted) is CMP is the Camshaft Position Sensor, and CKP is the Crankshaft Position Sensor.SHO--ripper:
CPS=CKP=PIP which isn't the CID or CMPsleep
