What the best plug wires?
kmanhooks
Ft Worth , Tx
I'm new to this, but since I have to put in plug seals I want really good plug wires. Any preferences? 92' 3.L
X
X-15 SHO
Guest
What's up I'm from south Fort Worth, did you just get your SHO? There is really no best wires for the SHO and they won't make a difference in performance so you might as well go with the OEM which are motorcraft and the cheapest at www.fordpartsnetwork.com for 83.99
X
X-15 SHO
Guest
How did you manage that Dale? I called and tried before and they said $138.99 at O'Reily's.
Dave Ladely
Seattle, WA
Taylor from Summit Racing cost about $80.00 and appear superior to Motorcraft to me, good thick silicone, fit great, look great.
Groo
Glenview, IL
If you want really nice, colored, high quality wires, go with the VI-TEKs from www.iptech.tv
They're slightly more expensive, but they seem worth the money. And, since you have an ATX, it would probably cost about as much anyway (although regular 3.0L motorcraft wires fit, but just barely).
The Motorcraft WR-4033 wires for the 3.0L also fit the 3.2L and are $83.99 from FordPartsNetwork.com. These are the best wires for the SHO engine and will serve you well for another 120,000 miles.
jbeano
Caledon, Ontario
I'm also using the Taylors and I'm very happy with them. I previously used the motorcraft and while they worked great I wanted to try something different.
rangerj
Brunswick, Ohio
In case anyone is interested!
The Ford part number for the plug wire set for the SHO is E9DZ12259A. If you search this number at fordpartsnetwork.com you will get the correct wire set at $83.99 plus S/H.
Happy Holidays SHO folks!
Has anyone heard from the Naval Aviator? Has he been deployed? Probably cruising the Med!
rangerj
