....the plenum supports.I need the thread size of the front plenum supports that bolt into the head to be more specific.Anyone know so i don`t have to pull it out and match at the store?(yes,i need a thread guage for home.)
If I understand you correctly, all the air intake plenum bolts are M8 x 1.25 - 8 mm with a thread pitch of 1.25 mm. Length is 25 mm for most of them. The special bolts that run along the center of the plenum are much longer - 50 to 60mmm (I think). These you have to get from Ford at big $$$$, $25 each eek! or a complete set at $125 (I think).jthomas68:
The head is large on the bolts you mention for the support bracket, but the thread is M8 x 1.25. I replaced some of those support bracket bolts with ARP studs and nuts.jthomas68:
I believe the M8X1.25 is also the same thread as the rod shifter stabilizer bolt.If that is indeed the thread i need,great.I have a few feet of it in threaded rod form.It was VERY hard to find,not something i`d like to do again.What i need is the thread size for the (2) plenum support brackets in front.I don`t think the M8X1.25 is the same,it seems much larger,but i could be wrong.I don`t need to replace the two bolts,it`s for a modification i`m working on.
You are JUST the guy I am looking for! Now I need to find a short term substitute intake manifold off of some junkyard SHO so I can send you mine. frownjthomas68:
I have no problems getting any bolts if i really need them.Since i an a Toolmaker by trade,i have a few machine shop connections still.![]()
