What is this tube called?
klobbs
Virginia
Okay I can't get any picture small enough to post it on here so I'm just gonna copy the link, and if you go down to step 23 its' the second picture, tube on the right, the tube comes out of the throttle body and goes down to the front valve cover. What is this tube called and where can I buy it? My old one was so brittle I had to cut it off with a razor. Thanks!
lowc
aka vapah lock
Quincy, massachusettes
stock will be fine or you can get the ones from sho source the come as a kit and are already cut for each location and i think that one on the vc is 3/8 might be wrong just bring a piece of the old one with you
itwonder
VA
That hose is part of the Positive Crankcase Ventilation (PCV) system. It normally supplies fresh air taken from just behind the throttle plate to the left valve cover. Crankcase vapors return in a hose that connects from the valley of the block to the underside of the throttle body. At WOT, crankcase vapors can flow to the throttle body through both hoses. As Off Road SHO suggests, use any oil resistant hose specified for PCV systems.
