water pump has been replaced, only threw one code before and it had to do with the O2 sensors, but i have since replaced both of them. EV replaced water pump, O2 sensors, valve gaskets, and intake gaskets. Cant find any leaks at all now. radiator just replaced. it was running like crap yesterday, it does good for about an hour or so, then starts dying if i let off the gas. Then, it will try and start back up, and will for just a sec, but if u try and give it gas it continually dies. If i then let it sit for say a couple hours, it will start back up and carry me for a while longer. I thought it was the radiator leaking on a sensor, and after letting it sit and rest a while, it was drying out and letting me go again, but now, i know that cant be it, because even after replacing the leaky radiator, i still have the same problem. the heat hand is holding steady, and i see no drips. so i guess u could say that if u let it cool off it will start back up, even tho im really not over heating, but it is happening after the car is nice and toasty
