I may have a right rear brake/caliper problem here.
For a coulple of weeks now I've noticed after driving for a while, usually on the way home from work, that it feels as if Im towing a load. So I jacked up the car and noticed that the right rear brake is sorta stuck. Wheel will turn but hard. This past weekend I did a little brake maint. lubed/cleaned up moving parts, brake pads are all OK. I thought this would help the sticking problem. NOT
What makes the calipers stick even after car is off. Need to replace caliper or is there a fix?
How do you tell the caliper is bad.?
