LJRuddy
Pop lock n drop
So I decided to finally make my sub/amp install look pretty today and one of the things I did was replace the signal wire that was shoved into the 20amp accessory fuse plug with a Tap-a-Fuse block. Crimped my XM radio wire and amp signal wire into the fuse and reinstalled. Instantly, the sub gave me a shit ton of feedback. For some reason, the amp is now getting power all the time with this tap-a-fuse installed. What happened? Does the accessory fuse always get power even with the key 'off'? If so, why did my sub/amp only turn on with the key on when the wire was just pushed into the fuse slot?
If you dont know what a tap-a-fuse is: http://www.autozone.com/autozone/ac...-25gq?itemIdentifier=32416&_requestid=1286581
