intimdatr
Got Cams?
you could just run the skin and build a small cage for it thats lighter to prevent it from collapsing.
Im going to bump this cause i need to pull more weight out but not sure where i should move next. I weighed in at 2840 a couple days ago and just removed another 45-50 pounds out. I imagine im around 2790 now.
The car has no dash, no interior at all, rear door panels cut out, lexan rear windows, no mufflers, carbOn fiber hood, and lots of other stuff.
Whats the most popular way to reduce the weight of the bumpers? How much weight could i save with a lexan rear glass? How much in the metal trunk bracing?
My goal would be around 2700 pounds and i would be stoked to see that.
You forgot you added your bumper then a 10lb bottle back in to the car...as opposed to when you weighed it at 2840 with no front bumper and no 10lb bottle.
-Sam
You can drill large holes in the inner bumper, and replace your bumper supports with alum, this can save you 20lbs. What kind of seats do you have? My Kirkey is around 13lbs IIRC. Brakes and wheels and susp add up as well. Smaller brakes, light wheels and tires, and coilovers can save over 100lbs compared to your average 17'' wheel, big brake Koni/Eibach setup.
80 pounds of sound insulation? Is that correct? Holy crap
