Water pump help
vance580
monroe, mi
ok put in a new water pump and now it whines like crazy not sure why am i supposed to oil the bearing through the little hole on the top when installing thinking it may be a bearing hum
vance580
monroe, mi
anyone please i've checked the tension i need to leave in an hour and now i may not be leaving at all dont want to drive it and have the waterpump pulley just snap off
yamahaSHO
E85 whore
Arkansas
Honestly, one topic is enough. Three threads on the same subject is rather annoying.
vance580
monroe, mi
well seeing as how everytime i have a problem and post here i never get any help so i figured i'd post in 2 forums but when i clicked the title i clicked down to put the same one and when i hit enter it posted it as water which doesnt say much
yamahaSHO
E85 whore
Arkansas
You received good advice from the first response on the initial post. If your belt is not too tight, it may just be a characteristic of that pump (if you're sure the WP is what is making the noise). I do not think your WP shaft is going to snap off with the pulley. Just keep an eye on your water temperature. Also, if you lose power steering, turn of the car since the WP belt also runs the PS pump.
vance580
monroe, mi
i checked the ps by turning the wheels and no change in noise i know its the waterpump cause everything sounded normal before and i dont think a waterpump is supposed to sound like this i can hear it plain as day sitting in the car with the hood closed and the windows and all doors closed it is really loud i went inside my house and even heard it in there nothing else was touched or changed in the belt drive system but the waterpump and it never sat just replaced it about 4 hours ago is when i started
Also i stuck my head near the belt area went back to front and the noise is the loudest when i'm right over the waterpump
yamahaSHO
E85 whore
Arkansas
Did you have the tensioner off? I've see people install the beveled washer backwards which causes it to lock up the pulley.
Honestly, I'd say drive it around locally and watch your water temperature and listen for anything odd.
vance580
monroe, mi
only had one tensioner off and i didnt take it off of the mount took the assembly off as one piece just the one by the alternator left the other one on and worked around it
vance580
monroe, mi
just took it around the block the whine is louder than my exhaust and my intake with the silencer removed i floored it and the whine is super loud loudest thing on my car right now i'm definitly not able to drive it cause that is definitly not right
Huntervf
Bored now
Back in Michigan ... again.
Did you get a reman unit? You may just have a bad replacement. I had something very similar happen with a reman alternator; a mere 30 miles after the install the thing started whining like crazy.
Did you remove the timing belt when you did the pump? I've heard cars whine pretty good when the timing belt had been tensioned improperly.
