Valve cover bolts
jcostantino
Coral Springs, FL
I'm putting the o-rings in my leaking valve cover bolts on Sunday. Where does the O-ring go? Does it go between the chromed washer and the valve cover or inside the valve cover? Do I need to apply any RTV anywhere?
Jeff
I use an O-ring that fits around the smaller diameter section of the rubber bushing and allows the bushing to fit into the hole in the valve cover with greater pressure.
jcostantino
Coral Springs, FL
I used the #40 o-rings that were mentioned in another thread.
I even managed to shear a bolt off in the damn head so... yippie. Being Sunday, 4pm when it happened, at my parents house working, and dog tired.. I used super black (grey) rtv to stick the bolt to the washer and the washer to the valve cover... it's not leaking, yet.
Can I leave it like this for a month or two until I do the valves? I'm going to check for oil tommrow to make sure that fix is OK and the other bolts aren't leaking either.
Jeff
